TC_Z's avatar
TC_Z
Need to Fix Paint and Decals
We have a 2007 Winn Voyage. It's exterior is the style with partial paint and decals (not full body paint). In 8 years the side facing the sun in storage has deteriorated, the clear coat has oxidized and the decals are peeling. I am exploring getting it repaired.
So far I have found I can purchase replacement decals from Mobility RV (also called Winn Parts).
I plan to get estimates from shops to restore the paint & decals in the Atlanta area, within hour drive or so. Please reply with shops you recommend.
Plus any lessons learned to get good results would be appreciated. Assume involves removing original decals, stripping oxidation, paint clear coat, apply new decals.
1 Reply
  • Not a shop recommendation, but if it were me I'd look into having the shop paint the new strips on vs buying more decals.
    The decals will fade again, the paint should be a one and done deal - and seeing as you're having work done anyway it might not be much more than buying the decals and having them installed.
