GlampinLife's avatar
GlampinLife
Need to replace gas spring on storage door - how many lbs?
I've got a couple of storage doors under my Georgie Boy Cruise Air XL that needs replaced. I know the length I need (20") but not sure how many lbs shock I need, obviously it needs to be enough to hold the door up but don't want to rip the bracket off the door because it's way too stiff. Other than the last door, all the other doors use 2 shocks per door. Suggestions on where I can find the correct lb to buy?
  • If you look it may be printed on the old shock ( it may not say LBS but be a number like 40, 50 etc).The ones on my door are rated at 50 lbs.
