werni9's avatar
werni9
NeverCold out.... going residential.
Any suggestions on Brands. Warranty effected if in a motor home? I am replacing the always wonderful forever 45 degrees Norcold 1201LRIM. Those dimensions are where I am trying to stay. Top freezer. I'm listening folks. Just can't buy a rebuilt or new cooling unit for a 4 door BOMB. thanks
  • Ivylog's avatar
    Ivylog
    Explorer III
    I replaced my cooling unit five years ago with a Amish one and while it worked better, it still was not great.
    The 21 cuft Whirlpool uses less than 100 watts AC when running as the compressor is not much larger than a grapefruit.
    Here are the model # that I found at Home Depot:
    Whirlpool refer on sale for $648 plus $99 for a ice maker...
    WRT311FZDW... white
    WRT311FZDB... black
    SS for $949.
  • I just replaced the cooling unit in my 1200.
    Everyone said to replace with residential but it would require taking the front windshield out and having a dealer do it costing hundreds and hundreds plus the trim work.
    So I went with a new Amish Built for about $1200. It works better than new.
    Easy enough to do. A helper makes it easier.
  • Ivylog's avatar
    Ivylog
    Explorer III
    It took awhile but I finally found a home refer that was very close... 1/2" too tall. DW wanted to save the drawer below our 1200 but unless the DW is fairly tall, having the freezer against the ceiling may not work. My DIY home refer install.
