theoldwizard1
Feb 17, 2019Explorer II
Gundog wrote:The size of the cable depends on the highest current draw and the distance. What does your inverter manufacturer recommend ? (2/0 sound like over kill.)
I have the tools and skills to build the cables but I am not sure what size cable they use I am guessing it looks like 2/0 welding cable.
I am also thinking of putting in a separate charging system on the batteries when it is stored. I leave the MH plugged in my inverter charger has a button that turns off charging to the battery bank. My thought is to turn off the charging through the inverter and using a better battery charger that will not over charge the unit.
How will the auxiliary charger be connected and how much current will it send to your battery bank ?
It sounds like you will have at least 2 or 3 connections for +12V (inverter/charge, DC distribution panel, auxiliary charger). I might be better to install a shield positive bus through a 100A fuse to the positive terminal on the battery. Also a good place to installed a Master Cut Off Switch.
