deprived's avatar
deprived
new doghouse out of wood?
I am in the middle of an extensive remodel on our 2008 Tiffin Allegro Open Road. I might have to rebuild part of the doghouse.
The current setup has two pieces consisting of a fiberglass shell, which is screwed onto the "firewall" and floor, and a hatch made of heavy plywood which also serves as the floor between the driver and passenger seats. The wooden section is fine but I might need to rebuild and replace the fiberglass part.
If I do rebuild the doghouse, I might make it out of the same heavy plywood as the floor/hatch section.
Is there any reason I CAN'T replace the fiberglass section with plywood? I believe that if the wood is strong enough and I use plenty of sound/heat insulation, the wood should be just fine.
Does that sound right or are there other factors I should consider?
  • I don't see a problem building the dog house out of plywood, except for a couple extra pounds of weight.
    A few pounds isn't going to be a problem. And, the wood should help muffle the sound.
