tpi
Nov 16, 2015Explorer
I have relatively light 25' class C and use tow haul primarily as braking aid on mountainous downhills. Otherwise I find the shifting excessive (sometimes on brief brake applications) and forces needless high RPM. I can see in some scenarios where there is potential to keep transmission cooler by using more mechanical gearing and less torque converter. OTOH I have never heard of any excessive (IMO) transmission temps when not operated in tow/haul-and of course the PCM has the data and can shift transmission according to temperature if they're excessive.
Bottom line: for me engine braking only when needed. I have no concerns about transmission life when serviced properly. Also E450 has more favorable axle ratio for reduced transmission heating than the E350-lower overall gearing.
38,774 PostsLatest Activity: Apr 26, 2026
