pnichols
Nov 17, 2015Explorer II
tpi wrote:
I have relatively light 25' class C and use tow haul primarily as braking aid on mountainous downhills. Otherwise I find the shifting excessive (sometimes on brief brake applications) and forces needless high RPM. I can see in some scenarios where there is potential to keep transmission cooler by using more mechanical gearing and less torque converter. OTOH I have never heard of any excessive (IMO) transmission temps when not operated in tow/haul-and of course the PCM has the data and can shift transmission according to temperature if they're excessive.
Bottom line: for me engine braking only when needed. I have no concerns about transmission life when serviced properly. Also E450 has more favorable axle ratio for reduced transmission heating than the E350-lower overall gearing.
Very well stated! We just completed a 10,000+ mile RV trip and I pretty much agree with what was said above. We covered just about every type of road terrain out there, including climbing to the top of Cadillac Mountain.
I use Tow/Haul mode sparingly - under only certain conditions - with our 24 foot Class C on an E450 chassis. I find the T/H Mode up-shifting "too soon and/or too abrupt" at times when accelerating from stops and when going uphills. Out of T/H Mode is often much smoother - which is probably due to torque converter slippage that is not allowed when in T/H Mode.
Going downhill I find T/H Mode down-shifting is great for the first down-shift on moderate downgrades, but often too abrupt and/or too soon for the second down-shift that comes with more brake pedal application after the first T/H Mode down-shift as the grade steepens. So when in T/H Mode on downgrades that steepen .... I keep tapping the brake very gently to just barely slow the RV a bit to keep T/H Mode from invoking the second level of T/H Mode down-shift. I do this to be able to use T/H Mode gently for downhill braking without the sudden jerk one gets from one more down-shift after the first. I hate having to use the shift lever to change gears on downhill grades, as it's much faster and convenient to slightly "baby" the automatic down-shifting that occurs when in T/H Mode. Our 2005 TorqShift transmission - when combined with the E450's pulling rear end differential gearing - could really use at least one or two more gears to put the gear ratios closer.
On the other hand - who am I to talk - as my driving methods may be completely wrong. When just starting out on the long trip I mentioned above, our TorqShift transmission failed after only around 51K total miles on the E450 chassis - which several mechanics said was VERY UNUSUAL. I had to pay a premium price for a one-day-turnaround installation of a heavy duty remanufactured TorqShift transmission so as to not delay the beginning of our trip much. I'm planning on installing a ScanGuage II(?), soon, so I can watch tranny temperatures from now on - even though I hate spending the money for it and know nothing about ScanGuage models or how well they work on 2005 TorqShift transmissions. :h
38,774 PostsLatest Activity: Apr 26, 2026
