pnichols
Nov 17, 2015Explorer II
Pardon me guys .... I should have stated that my 5R110 has 6 gear "ratios". I assume that Ford designed an actual set of 6 mechanical gears into the 5R110 in order to get 6 gear ratios.
Take a look at this link and let me know if I'm wrong about the 5R110 having 6 gear ratios/6 gears. Note that the 5R110 will never shift through 6 gear ratios in any given situation. It will shift using the 1-2-3-5-6 ratios in moderate/high temperatures and will shift using the 1-2-3-4-6 ratios in low temperatures. Only the the ECU has access to all 6 gear ratios depending upon temperature .... the driver/Scanguage only feels/records 5 gear ratio changes at any given outside temperature:
http://www.powerstroke.org/forum/general-6-0l-discussion/249526-5r110-6-speed.html
38,774 PostsLatest Activity: Apr 26, 2026
