pnichols
Nov 18, 2015Explorer II
My 2005 Itasca motorhome (it's 2005 Ford E450 chassis built in the fall of 2004) definitely had, and now still has, an 5R110 transmission in it - per the mechanics who recently installed a remanufactured 5R110 (with heavy duty options) in it. I have a Tow/Haul button on the end of the gear shift with a little white light that comes on when the button is depressed ... and it's labeled as "Tow/Haul". So .... Ford E450 chassis (I don't know about Ford E350 chassis) intended to be sold as "2005" chassis had the 6 computer available ratios TorqShift transmission in them .... or at least mine did.
When I pull away from a stop it shifts 3 times fairly quickly and as I start moving up to highway speeds it shifts a couple of more times. I call this "five speeds" .... or "five gear ratios" .... that my 5R110 goes through each time I come up to speed.
I can feel it's 1-2-3-5-6 gear ratio changes all the time. I haven't driven yet in cold enough weather so as to feel it's 1-2-3-4-6 gear ratio changes.
I can't imagine how the more recent "six speed" Ford E450 tranmisson would feel/shift any different to me - other than me feeling the individual 1-2-3-4-5-6 six shift points instead of my current five shift points. I consider moving in to, or out of Overdrive as a "shift point" .... because this is in fact a change in overall gearing ratio.
Read the various Ford enthusiast's discussions in their forums about the 5R110 TorqShift transmission. It will be cystal clear then about the 5R110 TorqShift being a 6-internal-ratio automatic transmission .... but with only five (1-2-3-5-6) shift points being felt by the driver in moderate or hot weather and with only the other group of five (1-2-3-4-6) shift points being felt by the driver in cold weather.
It seems crystal clear to me what is going on with 5R110 gearing ratios. Perhaps some folks have a problem with calling it a "shift point" when a transmission moves in to, or out of, Overdrive?
38,782 PostsLatest Activity: Sep 19, 2026
