HobbsHauler
Apr 02, 2016Explorer
It was a true floating floor. New carpet was put on the slides and everything else was Allure. Pilot and Co-Pilot chairs were removed and anything else that was on the floor. The 1/4 in. gap was left along the walls and the 1/4 round trim was attached to the wall not attached to the flooring. The shop did everything correctly, it was the product that was bad. They definitely lost money on us.
I hope that answered your question. :)
wolfe10 wrote:HobbsHauler wrote:
We learned from Ernie about flooring. We had a floating floor installed three times by a professional rv business and everytime we would take it out and have cold evenings, the floor would pull apart slightly and stay that way. The floor would look beautiful when we would pick it up from the shop, but the first night out in chilly temps, it would look like ****. They finally ripped it out and will not ever install in a rv again.
Good luck.
A question: Was it TRULY installed floating or were there "fixed" items on top of the floor. A floating floor in an RV is a HUGE amount of extra work, as every piece of furniture installed on the floor must be installed on a "platform" just a slight bit thicker than the floor and a molding used that ONLY, repeat ONLY adheres to the wall.
Any other method is a lot easier, but results in a "should be floating" floor that can NOT FLOAT and WILL warp/separate.
Inquiring minds want to know.
