- carringbExplorer
hpdrver wrote:
Where did you get the info about the 2022 chassis.
It's in the "2021 What's New" Publication, after all the Transit stuff.2021 What's New Manual wrote:
2022MY WHAT’S NEW E-SERIES NEW FEATURES
• Improved 7” diagonal rear-view camera screen in windshield rear-view mirror assembly
• Revised Shuttle Bus Package to include LH exhaust routing option for 158” WB – Order Bank Q2
• New scalloped engine access cover – affords greater leg/knee room in footwell areas
• FIRST TIME EVER - Standard Embedded Modem with improved performance, greater capability/bandwidth to support multiple Wi-Fi users
• Carbonized Grey replacing Magnetic
Note: This is a large PDF, so I don't recommend clicking if you're on mobile: 2021 What's New
Lot's of good stuff for the Transit in there. I suspect we'll be seeing a lot more motorhomes moving to that over the Sprinter. - hpdrverExplorerWhere did you get the info about the 2022 chassis.
- carringbExplorer
mleekamp wrote:
All I've seen, also on tube yube, is that the dash (gauge area only) is different, with a different steering column and steering wheel -- similar (maybe the same) as the current F series truck lines.
I've also seen 2021 Class C's on our local RV lot with the V10 chassis still used...most likely 2019 or '20 chassis the manufacturer stocks up on.
Ford skipped the 2020 model year, so it would be a 2019 chassis.
Ford is changing the doghouse for 2022, which starts production in January. No pictures that I've seen, but they promise better egress into the house from both the driver and passenger seats. - mleekampExplorerAll I've seen, also on tube yube, is that the dash (gauge area only) is different, with a different steering column and steering wheel -- similar (maybe the same) as the current F series truck lines.
I've also seen 2021 Class C's on our local RV lot with the V10 chassis still used...most likely 2019 or '20 chassis the manufacturer stocks up on. For example, our '19 Jayco C is actually built on an '18 E-450 chassis.
Our local dealer is supposed to have some 7.3 Godzilla's later this fall...so I'm planning on checking them out. (wife not happy about that!)
However, I'll say I still love my 6.8L V10. What a beast. - wanderingaimlesExplorerThe only thing I have seen is apparently some of the new Entegra ones are coming out. You tube and it doesnt metion driving or show the new doghouse.
38,778 PostsLatest Activity: Jun 10, 2026
