How many volts should we see... (I wish I saw 12.5) Depends on where you measure (I'm using the voltmeter inside the inverter).
IF measuring at the battery 12.5 is fantastic 12.6 is resting voltage full charge and with the kind of amps an inverter pulls 0.1 volt drop is amazing (on the good side).
If measuring at the inverter... Put inverter in standby (no load or minimal load) and note voltage... Then enable inverter and note voltage.. The difference is your "line loss" consisting of internal resistance in teh batteriesm, Wire loss, and connection loss.. this is your "Loaded" full charge voltage. Mine can go down rather far (I show 0.02 ohms resistance.. If I'm sucking say 1,000 watts (roughly 100 amps) that is 2 full volts drop. I'm still working to lower that resistance.
