BillHoughton's avatar
BillHoughton
Explorer II
Sep 11, 2015
New kid asking about campsite sewer/water connections
So far, our trips in the RV have been to places where there's no water and sewer connection at the campsite. Next weekend, we'll be spending three days in a place with those services at each campsite.
I've read through the owner's manual, and it seems pretty straightforward:
Water: Hook the hose up as if filing the tank, but leave the switch in what Itasca calls the "normal" position. Water will then bypass the tank, and it will be as if we're back at home, using city water. The fresh water tank's presently nearly empty, but that'll be OK, since the water's not coming from the tank.
Sewer: Hook up the dump line, but leave the black and gray water tank valves shut until they're full or we're leaving, then follow the usual sequence (black water tank first, then gray water, then rinse out the hose). Add the orange stuff that breaks down the solids and (supposedly) removes stink, just as normal.
Are there other things I should know?
Other than not having to drive to the dump station on the way out, is there any major benefit, for a short stay like ours, to connecting the sewer line at the campsite?
  • When I'm only staying for a few days at a site with a sewer connection, I don't bother hooking up my sewer line until I'm ready to leave. It's one less pathway for ants and whatnot to get into the RV. I sometimes find it easier to stop by the dump station than trying to hook up to the sewer connections at some sites.
  • You got it right! Like the others have stated, the FHU sites mean you don't have to conserve water, especially if you have smaller holding tanks, and you can give them an extra flush at the end. Good luck and have fun!
  • The major benefit is not having to conserve water. No sewer or water means being conservative flushing and taking navy showers.
    Having hookups means you can take longer showers and use a lot more water to flush which makes for a better tank dump and less odors.
    We used to leave our gray open but dont after I heard stories about bugs or critters getting into your tank.
  • Not having to haul water is the first thing that will be easier. There is also no need to conserve. For me, the advantage of full hookups is also the opportunity to flush the gray/black tanks better than can be accomplished at the dump station.
    CG owners may hate it (wasting water), but I will top off both gray/black tanks, dump....then fill again for a "clean" flush. I even have a stick that holds the toilet valve open, so I don't have to stand there watching it fill (DO NOT FORGET IT IS FILLING)..Final step, add a gallon or two and some chemical.
  • You'll need to add some water to your black tank if/when you use the "orange stuff".
    And you might consider getting a water regulator if you're going to be hooked up to a water spigot.
    Have fun and be safe!
