dougrainer
May 14, 2018Nomad
Amazing how easy replacing a part would go if people just READ the instructions:B From the INSTALL manual below. Doug
Control Units 9506, 9507, 9508 require a normally open switch. If you are replacing a 9513, 9516, 9590 Control Unit you must also replace the door switch. The new control will not work with older, normally closed switches.
