I also think it will work. But, I also think it is more effort than necessary.
If you were towing it from Point A to Point B and using it at Point B until you return home, it would be okay.
However, if you are stopping at several campgrounds, Walmart, etc., I think it would get old real quick.
And, if you are stopping at campgrounds, make sure they allow you to work on the car. I know it's a simple task to reattach the drive shaft but, some CG's may not allow any maintenance.
Try it for your shake down run, then decide if it's worth the effort.
