4x4 vixen wrote:
HI Fellow RVers I am new and green as can be. just bought a 1994 Dutch star gas RV and have tons to fix. first of all where is the master brake cylinder its not under the hood. second. does any one know of a used parts place in Canada. i need a tranny , drivers side windshield, side entry door, mirrors,cabin thermostat and a repair manual. I did mention i am GREEN but HUbby is having buyers remorse and I love this RV and want it on the road fast.
Well, along with the remorse, you hopefully got the thing, next to free.
It would help tremendously if you'll make the rig's info as part of your signature for much better responses. Now, having said that, is the chassis a Ford, Chevy or otherwise. With my Chevy, you can best see the MC by sticking your head up under the front driver's side wheel well or you can remove the dog house engine cover from inside the coach and look down on the left side towards the front. You should also be able to see the bottom side of it by crawling down under, but the frame may be under it and blocking the view, some.
As a side note, if you have coil spring front suspension and probably air bags inside the coils (after market coils are available that don't require air bags), then it's a P32 Chevy chassis.
Try eBay for a chassis manual and you might try these links for some parts...
ClickityOK and upon edit, you have a Ford and a solid front axle, but your Master Cylinder should be in the same place or there about.
See what I mean about the info and you made me type all that for nothing....lol:)
