Glimmerman911's avatar
May 28, 2026
Eagle Cap Owners - AC Wiring/Install
I purchased a 2008 Eagle Cap 855, and would like to install an air conditioner.
The brochure indicates the camper is pre-wired for air conditioner, wondering if anyone knows which vent the AC is pre-wired to, and if anyone has done this before, maybe what model AC they used and such?
  • wnjj's avatar
    wnjj
    Explorer II
    Did you ever get this figured out?  I have a 2007 EC950 and there are 3 holes.  Over the bed has the fantastic fan, the center one is the AC and the one near the door is a normal vent.  The AC is a Coleman Mach, 9200 BTU and our Honda 2000 runs it with no issue.
    • way2roll's avatar
      way2roll
      Trailblazer
      Op was a post and ghost. He never bothered to return to the forum.
      And where's Grit been?
  • The roof opening and AC dimensions are universal afaik. But you can check the specs and your opening to confirm.
  • It’s likely the forward vent. If one has a fan and the other doesn’t, likely that one.
    But it’s not really worth asking. Check one, if not there, check the other.
    Regarding what AC to buy, I don’t have specific recommendations, but a general one. I’ve only put one AC on a camper.
    General:  if planning to run off a 2k generator or household 15-20A circuit, find the one with the least power draw, ideally a soft start or add a capacitor yourself.
    It’s a little camper so I wouldn’t get hung up on a few more btus.
    Size:  Eagle Cap and the other “tall” campers hit at or just over 12’ tall to top of AC as that is typically the highest point.
    Our old AF TCs were just over 12’ tall on the truck with a standard height AC.
    Replaced the one with a low profile unit when I destroyed the first one. That allowed me to get in my 12’ shop door without airing down bags and tires to clear the door opening.
    If you’re not trying to clear a 12’ opening, this probably doesn’t matter to you.
    • StirCrazy's avatar
      StirCrazy
      Moderator
      what are you calling the forward vent?  I call the one in the bedroom the forward vent.  in my camper it is the middle one that has the ac prep package.
      • Grit_dog's avatar
        Grit_dog
        Trailblazer
        Ya idk, just a guess. Let me rephrase.
        There’s only 2 big holes in the roof in an 9’ truck camper. It’s one of the 2.
  • I have a newer adventurer (same company)  and what they did was put a box inside one of the kitchen cabnets and a chanel from there, to the vent beside it that a wire can be pulled through.  the older ones like your eagle cap might have the wire pulled through already and just be tucked up around the vent opening under the cover.   but if you find that box it will be the closest vent to it.
