Bordercollie
Mar 10, 2014Explorer
Have brake fluid flushed and replaced to prevent brake fade on grades,Have brake system checked and serviced as needed including replacement of front flex hoses. (flex lines can collapse inside causing sudden pulling in steering)Have all belts and hoses replaced if old/needed, radiator serviced as needed and replace belts and hoses as needed. Change oil in generator and check starting and proper function with roof A/C and microwave oven on. Check proper operation of furnace and water heater, fresh water pump, and total water system. Unfurl, inspect and and stow awning. Consider adding device to prevent unfurling underway. Have all tires inspected for sidewall cracking. Replace tires older than six year old per the date codes regardless of appearance/tread depth. Evaluate condition of house battery(s) and converter/charger. Consider installation of modern converter/charger that keeps batteries charged but not overcharged while plugged in to shore power for extended periods. Check condition of starting battery and replace if needed.
http://www.amazon.com/Progressive-Dynamics-PD9245CV-Converter-Charge/dp/B000GANZZ6
