SirPorkalot's avatar
SirPorkalot
New Owner of an Used (1990) RV here-What do I need to know?
I have just purchased a used Class C, here are the particulars.
1990 24' Fleetwood Jamboree Rallye on a Chevy chassis with a (rebuilt) 454.
I am somewhat handy and expect to have to do regular maintenance along with some irregular maintenance/repairs due to the age.
While the beast seems to be in decent shape overall, and all systems seem to be (currently) in working order, I am looking for advice from the folks on here about what to look for going forward.
1. What are the typical issues/concerns with these models I need to stay in front of?
2. Any tips for upgrades to make the beast more efficient/productive?
3. What upgrades do I want to consider for dry camping? (solar panels/inverters, etc)
Thanks in advance for any help.
John
  • Suggest you take at least one of the tires to a qualified shop to have them remove the tire from the rim and check the inside as well as the outside. If bad one can assume the others are also. Anything more than about 7 years old should probably be replaced.
  • Aside from checking for water leaks, were there any maintenance records with the coach ? Do you know when the anti freeze and transmission fluids were flushed/changed? How old are the tires - tread depth isn't as important as age ? Best of luck with your MH.
  • Welcome to the forum.
    As mentioned, water leaks are probably your biggest enemy. Use Eternabond and Dicor Self Leveling Caulk for your roof repairs and maintenance.
    Also, check the age of your tires. RV tires usually age out before they wear out.
    Welcome to the forum and congrats on yer new to you RV.
    Typical issues and concerns for your type of RV is:
    1. Water leaks.
    2. Roof & window leaks, especially the front forward facing overhead window.
    3. Water leaks.
    4. Water leak damage behind walls and in sub-flooring.
    5. Did I mention, water leaks?
    6. Roof damage from lack of annual maintenance.
    7. Water leaks.
    Good luck.
    Happy camping!!! See y'all down the road!!!:)
  • Water leaks and or water damage are your biggest concern by far. You might start with a seal test to see how many water leaks it currently has. Once you have those under control, then start searching for previous water damage.
    Next on the line IMHO would be to have the gas system pressure tested.
    Everything else will come.
