WyoTraveler
Jun 09, 2015Explorer
Have you checked all hatches, gaskets, latches etc.? If a hatch is hinged at the top a latch could be loose and not really noticed. Don't know which type of hatches are on that MH. Anything loose like that could cause a whistle. Assuming of coarse it is wind noise and not something under MH making the sound.
I had 89 MH with a 454 engine and the smog pump caused a whistling noise at high speed that drove me nuts until I found it. (It was a new MH) I put a hose exhaust on that pump and directed it rearward 20'. Solved the problem. That noise would come and go. Mechanic said there was nothing wrong with the smog pump.
38,766 PostsLatest Activity: Jan 10, 2026
