RLS7201
Jun 09, 2015Explorer II
I believe that coach has Atwood windows. If so, the drains at the outside bottom of the windows have been known to make a high pitch wine from the air flow at speed. Atwood offered plugs to cure the problem. You could tape the drains and see if the noise goes away.
Some food for thought. That 97 Ford chassis came with 235/85R16 Michelin all steel cord tires. The all steel cord contributes to the handling of that chassis. Less side wall flex. Only Michelin XPS and Bridgestone Duravis R250 tires offer all steel cord construction in your size. Both are pricey. Michelin XPS in you size are $255.00 each at Walmart. I elect to use Michelin XPS tires on my 95 Ford chassis.
Richard
Richard
38,766 PostsLatest Activity: Jan 10, 2026
