MrWizard
Nov 27, 2018Moderator
Angie
dig out the books
study the electrical
check your circuits breakers and the RV control panel
make sure the charge-converter (power converter) is turned on
this is what charges your batteries, when the generator is running
OR
you are plugged into shore power (aka extension cord)
i have a feeling you have NOT actually been getting any charge into the batteries
also somewhere could be near the entry door. or on the dash
are some ROCKER switches labeled AUX and Main these are battery disconnect switches (not to be confused with AUX start which is on the dash)
make sure AUX is in the 'ON' position (AUX is the house batteries, Main is the chassis/engine battery) these are for when storing the motorhome to prevent battery drain) (On is active/hot/use, OFF is disconnect/store)
other wise you get no power from the batteries and they might not even charge, depending on the particular wiring arrangement
i think 'Yahoo groups' has a Winnebago owners group, good place to get info and tips
also winnie factory is very good repository of any info you might be missing
dig out the books
OR
