The E-Series "Mobile Home Prep" package isn't carpeted. That's up to the coach "up-fitter." Phoenix no doubt does a better job than many, but I believe the masses of RV builders glue the cockpit carpet down. Might make accessing anything under there pretty messy.
Ron, I looked a the Forum you linked, but couldn't find the thread about this. Can you link it in detail?
Nearly all the shocks used in these Fords, have the customary nut on top, but they also have a hex surface as part of the very top of the rod. It's very easy to get a wrench into the fender well area and onto the top of that shock. Here's the Driver Side of our E450:
, on Flickr width=400[/img]
Here it is with a wrench barely visible inside the fender well. It's on the top nut of the Shock:
The open end wrench is below the shock mount/spring pad. The Spring has been removed. Notice now, how you have lots of throw for the open end wrench. There's nearly none with the Spring in place.
Here are the Older and Newer Shock Types:
New is on top. The Lower and Upper "Insulators" are now one piece each. For example, the Top Bushing, Washer and Nut come assembled. I think the Upper was 17mm and Lower was 19mm on Old, New is different and I forget what those sizes were. If you gotta have them I can work that into my busy schedule... Notice how short the stud is on the Old. Both shock shafts broke off, at about the same point. On passenger side, pieces went flying and I never found my Wrench or the Top Nut... So tie a string to your wrench!
What I hope to show you, is how you CAN get a "holding" wrench on the TOP nut, then work the Lower with an open end wrench. And, the working room you get by dropping the Spring out. It also gives you more room to remove/connect the lower shock mount.
Driver side is worst case. On passenger, I could probably get a flex ratchet and a socket in there, or a Gear Wrench with a floppy head. Much more room over there.
