jurob's avatar
jurob
New thermostat, does that it need a delay?
Have a 97 Gulfstream with 2 Coleman ducted 13.5k and 50 amp service. Also has 6600 watt generator.
has 2 thermostats and old says, built in time delay and fuse protection.
Replaced 1 with a standard analog Coleman thermostat without delay. Going to install a second one and just realized it has no delay.
Do I need a delay?
  • "Standard analog" - I hope that does not mean it 'must be level' to be calibrated. This can swing on and off while driving, that would be REALLY bad. . If it is magnetic (you can hear it click on and off) then that is acceptable, but the old mercury filled thermostat will not work right while the RV is moving.
    Anything that is electronic should work well. It might run on batteries, that might need to be replaced once a year. Leaving it in the 'off' position while in storage might prolong the battery life to 3 years. .
    Many electronic thermostats will have a built in time delay.
    The time delay is required to prevent the compressor from shutting off, then being turned back on within 3 minutes. This 'short cycle' can damage the compressor windings. If you can 'remember' to not shut off the compressor, then turn it right back on, the thermostat without the built in time delay will work great. . .
    Good luck,
    Fred.
