Sounds like 30-ft and 19.5 wheels make this a Class A. If so, click "Notify Moderator" and ask to have it moved.
A tire dealer can look up the Offset Requirements for the existing and proposed tires. Then measure Offset of the Rims. Offset is the distance from the center of one mounted rim to the center of the other. For one wheel, distance from center to mounting face.
Say your old tires require 9" offset and your rims are 10". That's OK. Extra space between sidewalls doesn't hurt a thing. Now say your new tires require 11" offset but the rims are 10". No good! Sidewalls will rub and the tires will fail.
