msturtz
Mar 12, 2015Explorer
I would count on you wanting to add Hush Mat or some other high temperature heat and sound shielding. The V10 units can get very loud. The shield will also help with heat. Dash AC is a challenge if you use the roof AC to cool the coach and remove the humidity then properly running dash AC may be able to keep up. The F53 units only have a 80 gallon fuel tank so running the generator will further reduce your range. Humidity is your enemy so keep the windows closed and consider installing a mechanical dehumidifier. Try to keep the humidity inside at less than 35% RH.
38,769 PostsLatest Activity: Jun 25, 2013
