ReneeG wrote:
I'll keep it simple on two points: 1) storage and 2) are you going to tow?
We almost purchased a Class A going from a 32' TT. After DH asked me where I was going to put the garbage can, I began looking around. Not much storage.
We were going to take the first few trips without a toad due to the cost involved in the setup. Another thing to take into consideration.
In addition,when we took the test drive, it really rolled and I get car sick easily. DH said we can solve that with sway bars, which will probably fix your problem when semi's pass.
We've thought about both. If you are talking about storage under the unit, I scope that out first. Our TT has minimal storage. Most Class A's have much more. The surprise to me is the limited thru storage. Have to make sure you have some to be able to store a popup canopy. Our folding chairs are fairly long when folded up.
We probably won't tow early. If we are close by, we can drive a car. If we go distance, we can rent or Uber. A toad will be down the road a bit.
