humblerb wrote:
The one item I mentioned that I am really curious about now is running the generator while driving.
I would never have thought that would be something you would want to do.
Now that I know it is possible, I wonder if it is actually necessary.
Do you need to run it while driving so the AC or Heater can run while traveling?
You certainly do for the roof AC's to operate, as they won't run off of an inverter and the dash air is usually not enough on hot days.
Propane heat will run at any time and as long as your house batteries are up. Electric heaters of most any sort, requires the genset, as well, however a small electric plug in heater would probably run OK from the inverter and with the engine alternator keeping the batteries up. Still a waste of time an energy, usually and the dash heat works pretty well, except in below freezing temps.
