wolfe10 wrote:
If storing diesel for over 2 months in summer or 3 months in winter, add a BIOCIDE such as Biobar JF.
Then fill the tank to minimize condensation.
Run engine and generator long enough to get them fully up to temp (like 25 highway miles) and park it.
If in very cold climates and you filled in the summer/fall, add an anti-gel. Walmart carries PS brand.
Condensation has been shown to be a myth. If you change the air space over 100% each day as the temp falls then rises and you squeeze every molecule of water over 100% humidity air...a 50gal tank might generate the equivalent of 3-4 peas volume of water. In reality, you won't be at 100% humidity and you won't squeeze every last molecule out.
Doubly so, with modern vehicular fuel systems which aren't open to the outside air.
Anti-gel only matters if you will be using it during the winter. If you are putting her away for the winter with no intention of using her until spring, the fuel will gel as it gets cold, then it will un-gel when it warms up.
