Grit_dog
Aug 24, 2020Trailblazer
There may be slight variations, but generally the same size and class of tire has the same load index rating and the same or very similar capacities vs pressure.
You may have over-inflaed tires. The camper is empty though, correct?
Like you said, 400lbs of water, everything packed up in it, may have another 1000lbs easy on the rear axle when you set off loaded for camping.
