Thunderbolt's avatar
Thunderbolt
Rough Idle
I have a new issue will my 03 Chevy 6.0. When the truck is cold it idles rough. Doesn't actually feel like a misfiring cylinder. In gear at a stop light the idle will drop below 500 rpm and the engine stumbles and then the idle jumps up to about 1,000 rpm and then back to normal for a moment and then it repeats. Once it was up to operating temp it idled fine. Since it only did it when cold most of my research showed tat the intake manifold gasket was the likey the problem.
Now this morning the temp outide was -6 degrees and the truck ran rough until it was warm and then it was fine as usually. Then 25 miles down the road I run into traffic and had to stop and the truck did the same rough idle as it was doing when it was cold. It did it about 5 or 6 times and then idled fine again. Warm or cold it runs fine once you are off of idle. Looking for some input.
