coolmom42
Aug 25, 2020Explorer II
Grit dog wrote:
There may be slight variations, but generally the same size and class of tire has the same load index rating and the same or very similar capacities vs pressure.
You may have over-inflaed tires. The camper is empty though, correct?
Like you said, 400lbs of water, everything packed up in it, may have another 1000lbs easy on the rear axle when you set off loaded for camping.
Good to know. I think I'm going to fill up the water tank, load some stuff into it, and get some weights. Proceed from there.
