redline_771's avatar
redline_771
new to rv'ing just purchased a 1996 31' allegro
new to the world of rv'ing, just recently purchased a 1996 allegro on a ford chassis, odo 31,800miles, 600hrs on generator, fair to good inside and out, 2 roof top a/c's, hydralic leveling jacks, all main components seem to work. they were asking 12,000 but since my wife works for them, they let us have it for 8000.00. from the research i've done on the web i couldnt fing a better price and condition. just want some info if i got a good deal, and what i should look into checking more deeply into the rv....thnks
  • First off, you got a great deal.
    Secondly, I would get a good fuel system cleaner, personally I use Lucas products, and use an extra strong dosage. With the age of the MH and the low miles it could have a lot of crud in the tank and lines that the cleaner will take out. After you have run that tank full through then change all fuel filters, change the oil and filter, thoroughly grease the chassis and drive line, change out the brake fluid so it is all new, I changed the differential fluid on mine and the transmission fluid and filter also.
    As noted by Cpartjr the tires will probably need changing. They may look good, but find the date code on the tire, anything over 7 years old needs to be replaced. RV tires seldom wear out, they age out. Toyo, Hankook, Sailun, etc. are just as good if not better than Michelin and Goodyear and are cheaper to purchase.
    You may also need new shocks, air bags, steering stabilizer, and a tune-up. Basically you need to start at the front bumper and when you reach the rear one you will have checked and repaired everything. This means doing it twice, once for the chassis and the second time for the coach.
    Congratulations on your new MH and may you have many great times with it.
  • Welcome to RVing. Hope you have many happy safe miles in your RV.
    One of the first things I would check is the age of the tires.
    Chances are with an RV this old and few miles compared to age, the tires
    may need to be replaced.
