pianotuna
Nov 13, 2014Nomad III
Hi,
My auxiliary 20 amp and 15 amp shore power cords feed into the RV via the shore power cord box. They go to "extra" female outlets that are rated for 20 amps. I could see no need for making more holes in the RV.
It is currently -9.9 c (14 f). The RV is at 21 C (70 f) and I'm using 2900 watts. Low tonight is forecast for -20 C (-4 f).
To see a list of how I heat have a look here: How I heat
Malakie wrote:
I did that for the small ceramic heater I put the fresh water tank and water inlet bay in the back.. It is set to 44 F on the thermo. There is another jack where I could run another line as you mentioned.. problem is getting in INSIDE the RV somehow..
38,763 PostsLatest Activity: Dec 13, 2025
