RayChez wrote:
krivanj wrote:
Some rvs only have three as to not stress the chassis. Misadjusting with four can really stress the chassis to the point that windshields pop out. That is why most jacks always raise or lower two at a time.
A person should have some mechanical know how before he even drives one of these things. They should learn how to use the levelers by just learning how to center a bubble on a level. Most coaches come with a leveling system where you do not have to be a very cerebral person to follow the little bubble and keep it centered.  The one jack in the front used by many coach companies is really not to prevent twisting of the frame. Reason why they use only three is to save money.  The three point system is really not that good because it puts a lot of pressure on a pivot point instead of spreading the weight to two in the front of the coach. Another fault of the one jack in the front is that if you have to lift your coach high and remove any stabilization used by the wheels, you will have a coach that will rock from side to side as you walk inside or stepping into the coach.
You would have to put a tremendous amount of pressure to pop out a windshield. Most of the windshields that I have seen pop out was not because of somebody not knowing how to level their coach. The two that I witnessed were driving into RV parks that were not level and had big hills to climb, and the twisting would be at the turn of the climbing. Such a park is at Bay Landing in South Carolina.
I'll have to agree with the faults of the 3 point system and will take four over three, anytime. As for windshields popping, It's my opinion that the the thing wasn't built right in the first place and can't even imagine that sort of thing happening to ours for any reason. For leveling, we've long since forgot bubbles of any sort and now just go with the bathroom door, staying put, at 90 degrees open. That with the coach looking good from port to starboard, has been working well for us and we can usually do this pretty quick.
