Jrork
May 17, 2015Explorer
New to the V10.. Low fuel pressure
HI everyone. We recently purchased a 2001 motorhome that's based on the F53 with a V10. I noticed that it seems to be hard to start and while it has a strong cranking action, it takes a bit to get it to fire.
I checked the fuel pressure and sure enough, with no fuel pressure showing it takes quite a bit of cranking before it even shows 10 lbs. A bit more and it gets to 20 lbs and starts. It stumbles for a second and then smooths out as the pressure gets up to a high of 28 lbs. Rev the motor a bit and it drops to about 24 lbs.
I swapped out the fuel filter and there was no change.
I disconnected the fuel pressure regulator and instead of the pressure climbing much, it only raised about 1 lbs.
I'm thinking I've narrowed it down to the fuel pump but wanted to double check first. Any thoughts or suggestions?
Thanks everyone.......John
