j-d
Mar 26, 2017Explorer II
BigCanoe wrote:
Its on the 2007 chassis with the less "bold" grille.
There are "improvements" every model year. In 2008, when the appearance changed, the interior did too, but the BIG improvement was FAR better Front Disc Brakes.
Don't ever "Do a Brake Job" on an E-Series 2007 or earlier. Get a 2008 or newer setup from a company that converts E250/350/450 to 4x4 using F350 parts. You can buy new assemblies, taken off of vehicles being converted, for no more than Pads/Calipers/Rotors for yours. The 2008+ components are bigger throughout. Larger diameter, thicker rotors, Bigger, thicker pads, Bigger calipers. I got a whole front axle assembly with brakes and radius arms from Quigley in PA. There's U-Joint Offroadin Fletcher NC where Chris might be able to help you. And Northwest Quad Van in Portland OR, but shipping gets steep on heavy parts.
For others: Buying a take-off axle assembly is less expensive than doing a ball-joint/bushing job, too.
I got the whole front "kit" from a 2012 chassis, and the ride, steering and especially BRAKING of our 2002 are all greatly improved.
38,782 PostsLatest Activity: Aug 31, 2026
