EMD360 wrote:
I might reinforce the shelf more. It’s screwed into the back with drywall anchors and to the plywood on the closet side and I used long screws through the cabinet bottom into the middle piece. But your mention of long bolts makes sense. Think
I’ll add some through the cabinet bottom with nice large washers. Just to be safe. Oh and it’s a 350e though still plenty rattly.
See how a piece of angle iron looks on the bottom of the coffee-maker box. I would try to "support" it then bolt it thru, allow some weight to ride on that angle iron, acting like a shelf. Reason being, you do not know how well the OEM cabinets are secured. RV assemblers have been known to miss the mark hitting a solid stud.
See how it drives on the open road, how it handles . A good positive caster alignment on the Fords works well.
