last night I went to Walmart with my 12 yr old grandson to buy some football gloves for him and ended up buying a 29" led tv to replace the 13" old analog one. I still have to modify where it hangs s...
On my set up, there is a little button right on the antenna lead hook up plate. This is the outlet plate where you screw on the wire that is coming from the TV. It is actually a built in signal amplifier. If you don't push it, you will not get a signal at all.
