Deano56Explorer IIOct 09, 2013New TVlast night I went to Walmart with my 12 yr old grandson to buy some football gloves for him and ended up buying a 29" led tv to replace the 13" old analog one. I still have to modify where it hangs s...Show More
rockhillmanorExplorer IIOct 10, 2013x2 digital TV's work with all RV antenna's. The booster is what makes them work. If your red light is out you either have a wiring problem to the unit or it needs to be replaced.When you get that fixed all you do is hit scan.I full time and I never have less than 10 to 15 channels with the MH antenna. Good luck hope it's just a loose wire to the booster!
