ok, just an update, the original cable from power source to antenna is bad, as mentioned before I cut behind the slice I saw only to find that didn't fix the problem, tonight I cut back a few inches at the other end where the cable attaches to the antenna. That cable makes a very sharp bend to miss the support legs, still the cable heats up and I have no signal. I tried to pull on the cable but it does not move and I am concerned if I pull too hard I could pull the other cables loose from something, so I am done. I could run a new cable along the roof and drop down over the side and through the side window but really don't like that look. Anyone have some ideas that won't look rigged?
