wa8yxm
Jun 04, 2014Explorer III
Unless you made major changes to the plumbing that is flat impossible, since the pump only pumps COLD water.. It flows to several "T" fittins, one of which taps off to the water heater where it becomes HOT water.. The line (Past that "T") has to either have a valve closed (And no such valve should exist) be pinched or.. here is a check valve and again in a place where no such valve should exist.
SOME water heaters do have a check valve on the inlet however.
38,769 PostsLatest Activity: Apr 24, 2002
