Golden_HVAC
Jun 04, 2014Explorer
Hi,
My guess now is that you have a factory installed hot water heater bypass system. Since your pump is putting out cold water to the outside shower, and hopefully both of those valves are off, (sometimes people leave the valves on yet have water shut off at the shower head and do let cold water into the hot lines) your pump is pumping cold water out to the main line and perhaps factory installed water filter (located in the basement compartment of most high end DP's).
From there, I am guessing that you have a water heater bypass, and it should be set to not bypass. Look for valves or instructions on how to operate those valves in the pump compartment, or near by.
Good luck,
Fred.
PS: If you want someone with a Phaeton help, consider edit your original post to say "Need help with water heater bypass Phaeton" and you might get more Phaeton owners helping out.
Good luck,
Fred.
38,769 PostsLatest Activity: Apr 24, 2002
