lpsquared's avatar
lpsquared
New York State Inspection
Have a 2000 Winnebago Brave 33, gasoline powered and registered in New York State. Is a state inspection required ? I know in New Jersey they are no longer required.
Cheers Layne
  • If your motorhome GVW is under 18,000 lbs, it's classed as Group 1 Light Vehicle and can be inspected by any inspector that's Group 1 qualified (most are). The inspection facility must have a bay large enough to bring the vehicle inside though, they are no longer permitted to do inspections outside for some reason. Group 1 vehicle owners over 10,000 lbs can also request a "Heavy" Group 2 inspection instead of a Group 1, in which case the inspector must be Group 2 qualified of course.
  • Yes at a large truck inspection station.
  • Bruce Brown wrote:
    It is required. You'll need to go to a larger truck place too, a normal car inspection place can't do it.
  • Welcome to the fourm. I believe inspections are required if you can believe the internet.
  • It is required. You'll need to go to a larger truck place too, a normal car inspection place can't do it.
  • Such as here:
    https://dmv.ny.gov/inspection/inspection-requirements
  • I'm surprised the NY vehicle department didn't answer your question in an on-line website!
