rk911
May 18, 2013Explorer
rcsauce wrote:
Hi,
I am new to RVing and I just got a tow dolly. One thing I found out was that I need to leave as much slack as possible on the mag tail lights. When towing the Dolly just a few miles to get home They got disconnected.
Do you have any other suggetions?
Thanks in advanced!
since you're brand new to RV'ing i'll ask...do you know what the various weight ratings are for the MH, what your MH weighs when loaded for travel and what the combined weight of your dolly/vehicle will be when loaded for travel? and area you sure that your vehicle can be safely towed on a dolly? a common newbie mistake is believing that you can just pop any old vehicle onto a dolly, hook it up to the MH and hit the road. don't feel bad if that's you...it was me too back when I was a newbie. we've all been there. you've already got the dolly and vehicle but it's not too late to be sure you can safely tow the combined weight of the dolly/vehicle.
you need to know just how much weight your MH can safely tow without exceeding the various weight ratings...gross combination weight rating (GCWR), gross vehicle weight rating (GVWR) and each axle's gross axle weight rating (GAWR). you also need to know the curb weight of the vehicle you're planning to buy and whether that curb weight includes a full tank of gas (sometimes it does, sometimes it doesn't) as well as the empty weight of the dolly.
the maximum amount of weight you can safely tow will be the lesser of the following:
- the GCWR minus the actual weight of the MH as it is loaded for travel (food, fuel, water, LP, clothing, supplies, pets, people and misc. stuff); OR
- the weight rating of the MH hitch (Class II 3500-lbs, Class III 5000-lbs, Class IV 10,000-lbs); OR
- the weight rating of your towbar
load up the MH as you would for travel and then get individual axle weights at a certified scale. compare those axle weights to the published gross axle weight rating (GAWR) for that motorhome. the actual axle weight must be less than/equal to the rating for that axle. add the two axle weights to arrive at the total rolling weight and then apply the three conditions above. assume nothing.
good luck and safe travels.
38,778 PostsLatest Activity: Jun 10, 2026
