CZSteve's avatar
CZSteve
Newbie - Class C Motor/Brand questions...
We're considering getting a Class C that will be shared among our family members (Myself, DW, 16 Y.O. son & 13 Y.O. daughter), my parents and my brothers family (Married w/ two kids - 10 & 7).
Looking at a used Class C from 29' - 31'
General Things to look for and motor question: Most seem to be Fords on an E450 chassis with a 6.8 Liter V-10; we do see a few Chevy's w/ a 6.0 Liter Vortec V-8.
(Yea, we'd love to have a diesel but seems most C's are gas and what our budget allows...)
1. Is mileage on a Class C equivalent to what you'd see on a daily driver truck or car? I know maintenance is a big component and cars can rack up more miles today compared to twenty-thirty years ago - On average, what's considered 'high' mileage for a Class C?
2. Quality/Longevity of the Ford 6.8 VS Chevy 6.0? Other recommendations?
3. Ford VS Chevy (or Dodge) recommendations regarding chassis, transmissions, etc?
4. Understand the cab-overhang is something to check for water leakage - Any other key things to check and watch out for?
Thanks,
Steve
  • As already noted there is not to much difference in the in the 2 main chassis that the Class Cs are built on the Chevy Chassis will give you a bit more advantage in ride and comfort and the cabin is larger.
    The longevity of both is a matter of good maintenance if properly cared for 200000 miles is not out of the question, just look at any Rental Fleet there are many happy owners that have had no problems with high mileage RVs.
  • Hi make sure the wheel base to length ratio is no lower than 50%. 55% on a 26 foot E-450 is ideal and makes it feel as if you are driving a regular but *large* car.
  • DrewE's avatar
    DrewE
    Explorer III
    Both the Ford and Chevy chassis are good designs, largely comparable though with some unique strengths and weaknesses. With a little bit of care, either one will generally outlast the house part of the motorhome in most situations.
    As far as mileage, I would not generally even start to be concerned with the chassis under 100k miles. The Fords often get over twice that when used in other vehicle types such as shuttle busses, etc., and I think the Chevys do likewise. Most commonly the mileage on motorhomes is rather on the low side anyway.
    For the Ford chassis, the newer ones are generally a little better, though there haven't been too many significant changes since around '97 or '98 or so. The oldest ones will have a four speed transmission and this can be recognized by the labeling of the shift lever: it will have a switch for "O/D Off" rather than "Tow/Haul". Besides the transmission changes, there have been improvements to the engine; in particular, the early versions have a somewhat marginal design where the spark plugs screw into the head with barely enough threads, and so have a bit of a tendency to eject spark plugs if they aren't installed and torqued with care. Getting one with the five or six speed transmission will avoid this weakness.
    Your fourth question is probably the best one. I would pay as much attention as possible to the condition of the unit, particularly the house part, and not worry too much about details of the chassis; that's where you're likely to run into big problems. Water leaks are the biggest concern, and the cabover area is one common place for them to occur (but not the only possible location). Look carefully for discolored ceilings, for blistering or delamination in the walls, for soft spots particularly in the corners of the ceiling and the walls or on the roof surface. Some would say run away from the slightest sign of water damage or intrusion; I don't go quite that far, depending on your budget, but do pay careful attention to it and be prepared that it's usually worse than it first appears if there is any. If it's at all extensive, do run away unless you specifically want to restore an RV; it doesn't take too much to greatly compromise the structure of most motorhomes.
    Have the seller demonstrate that all the appliances and systems are working properly. Make sure the fridge cools, the water heater heats, the air conditioner and furnace work, the generator starts and runs well and doesn't stumble under load, etc.
    Check how new the tires are (based on the DOT date codes). Most tire manufacturers recommend a professional inspection annually after around seven years, which involves dismounting the tires to check the inside as well as the outside, and replacement in any case after ten years; most RVers replace after seven years or sometimes fewer. Usually the tires will age out of service before they must be replaced due to treadwear. A new set of (six) tires for a class C is an expense of $1000 or more, depending on the deal you get on tires--usually more for brand-name tires. A blow out can cause extensive damage, besides the obvious danger of causing a crash.
    Check the weight carrying capacity of the motorhomes you look at. Some class C's have very little payload available. Some (quite old ones) were above the chassis weight rating empty when they left the factory, but you probably won't run into one of them.
  • j-d's avatar
    j-d
    Explorer II
    There's a 31' Winnebago Class C a couple sites down, on a "Workhorse" (modified Chevy) chassis. They're good, but rare. The newer Chevy "4500" is also good, but very late model and rare.
    The Ford E-Series is good and very common. Chevy has a bigger cockpit and a little better handling. Ours is 31' on Ford E450. Good, strong powertrain and a rugged chassis. 2008 and newer is best, 2005-07 is next, then 2000-2004, then 1997-1999, all V10's. From 1992-1996 they looked the same but had 460 V8's. All E350 till 1996 (I may be a year off on that) then the E450 came out but was called "E Super Duty" for a few years. Door jamb label: If GVWR is 14050 or 14500 it's E450.
    Towing our Corolla, our 31' on E450 gets 8 MPG at 60-65 on the open road. About typical. Shorter ones do a little better. Chevy does a little better. By that "little better" I mean not more than maybe 1 MPG.
  • "1. Is mileage on a Class C equivalent to what you'd see on a daily driver truck or car?"
    No. Not even close.
