Johno02
Apr 18, 2017Explorer
The ones from Walmart are fine. We like the kit that has two 10' sections, in most cases one section is enough for us, but have used both at times. At least once per season, I put the whole thing, hoses, connectors, and all in a large plastic bin, and fill it with water, bleach, and detergent. Let it soak for a while, stir it around occasionally, then rinse well and lay out to dry. Then store it all back in rig. With the short hoses, a good trick is to carefully compress each section as much as possible, then fasten the ends together. Makes it a lot smaller and easy to store for the section you don't use.
