RambleOnNW
Apr 19, 2017Explorer II
I have been using the basic Camco Revolution hose set for the past several years. 2 10' sections with caps. 1 10' section has one end permanently attached to the dump outlet in our wet bay and then drops through the floor into a sewer boom.
This has worked great, pop cap off sewer boom, take cap off hose, attach 90 degree fitting, stretch to drain, dump. Then reverse the process.
Lately the hose has started to leak around the lower end fitting which isn't a big issue for dumping since it leaks right into the drain, but when compressing the hose back into the boom and putting the cap on, the hose does not stay compressed due to the leak at the fitting.
Looked around at some of the alternatives and online reviews and decided to stay with what has worked, the Revolution hose.
