fttang
Feb 24, 2014Explorer
ffjeff wrote:
I would got to FORD and get a body builders handbook for your E series. Ford produces these to prevent up fitters, especially from the RV industry from doing things that will void the warranty and more importantly something that will affect safety. It is part of the FORD QVM program.
All the power tap points are there, shielding requirements, rear AC, body areas that you can cut etc. Great reference for all the chassis wiring as well.
thanks for the input,
i only found this manual type that seems would come with incomplete vehicles, something like this
https://www.fleet.ford.com/TRUCKBBAS/non-html/2004/04ivm_eseries.pdf
i only plan on drill a couple of round hole for electric and water on the side panel anyway so that's probably not a problem.
would be interested in the other things you mentioned but couldn't find those info in the on i found.
38,769 PostsLatest Activity: Apr 24, 2002
