full_mosey
Feb 26, 2014Explorer
booster wrote:
Here are the chargers that Lifeline recommends, even puts their name on. Note the many comments in the text about proper charging parameters and increased battery life. Ctek chargers are something like 6 step chargers.
Lifeline charger recommendations
You might find it interesting that none of those chargers would be appropriate for a 220AH pair of 6Vs. The largest 7000 model is only recommended up to 150AH. There is a big difference between cyclical and standby charging. None of the cited chargers are adequate for cyclical charging because they fall below the minimum 0.2C charge rate in 5.4 charging. Also note they lack temp comp!
Again, I recommended an appropriate charger for cyclical/RV use.
HTH;
John
38,769 PostsLatest Activity: Mar 31, 2026
